Old 06-19-2009, 06:02 AM   #1
Mike Savelle
Liked 7 Times in 5 Posts
Smile LT1 starting
This car has a real long crank when hot . has 36 lbs fuel pressure and runs fine once you get her going. When cold it has a long crank some times .Any ideas , i hate to go out of town with it . Mike
Mike Savelle is offline   Reply With Quote
Old 06-19-2009, 06:17 AM   #2
Liked 1,822 Times in 413 Posts
Default Re: LT1 starting
I don't think 36 psi is enough fuel pressure. If memory serves correct, Chevrolet specified 42 psi, and it usually tested well above 50 during cranking.
Old 06-19-2009, 11:05 AM   #3
Mike Savelle
Talking Re: LT1 starting
I was afraid it would be the pump. I don't think its easy to get it out ,and i don't want to cut a hole in the floor. thanks for the input .......... Mike
Old 06-19-2009, 01:39 PM   #4
JimFarrell
Liked 21 Times in 6 Posts
I had the same problem with a 97 Z28. Replaced the pump, now it starts instantly. The pump isn't to bad to replace. It took about 2 hours.
JimFarrell is offline   Reply With Quote
