Guest
Posts: n/a
For all you Q jet guys out there I was wondering what size needle and seat you run in your combos. What size can you run up to? I've hear .140 is max. Thanks in advance...
Liked 1,831 Times in 415 Posts
A 0.140" needle and seat is about the maximum size. It is important to note that the larger the needle and seat is, the lower the maximum fuel pressure is.
Alan Roehrich 212A G/S |
I use the Edelbrock one in my carbs, I think that they are a .149 if I remember correctly.
Liked 5,125 Times in 1,953 Posts
Todd, I've tried modifying some with larger seats than .140 . There's enough room on the needle for a little more, but they didn't seal well. Probably not enough leverage from the float.
Grose Jets supposedly flow more @ a lesser opening, but I never had good luck with them on a Q jet.
DITTO , get the kit
Bud Lefevre 3075 STK IHRA World Record Holder |
