Old 06-10-2009, 10:43 AM   #1
NORMAN BARNARD
Liked 2 Times in 2 Posts
Default Need carb. Help
I have a old afb carter carb. P/n 3633-s that i need to know what stock jets and rods came in it. Carb. Is off a old 64 buick with a 401 motor, this is a restoration job.
Any help would be appreciated. Answer on the form or send me a pm.
Thanks.......norm
NORMAN BARNARD is offline   Reply With Quote
Old 06-10-2009, 11:13 AM   #2
Larry Fulton
Larry Fulton's Avatar
Default Re: Need carb. Help
based on info in the OLD MANUAL that I have,
3633S = auto trans 401" calls for
Prim. Jet @ .092" (pn.-120-256)
Sec. Jet @ .082" (pn.-120-158)
step-up rod = pn.- 16-219
1 step lean = pn.- 16-252U
accell pump shooters @ .028"
Hope this helps!!
Larry Fulton
Larry Fulton is offline   Reply With Quote
Old 06-10-2009, 11:34 AM   #3
NORMAN BARNARD
Larry,
thanks for the info. The carb. The jets/rods. That are in it are considerably
leaner (primary) causing the surging going down the highway. Question: Would you also have the venturi/booster spec's for this carb? Just want to make sure everything else is ok, also the factory cfm rating.
Thanks for your time and info.....norm
Old 06-10-2009, 12:13 PM   #4
BlueOval Ralph
Banned
Check this out
http://www.arnolt.com/articles/carterafbtuning.pdf
http://www.carburetion.com/Carter4.htm
Originally Posted by NORMAN BARNARD View Post
Larry,
BlueOval Ralph is offline   Reply With Quote
Old 06-10-2009, 05:19 PM   #5
NORMAN BARNARD
Ralph,
thanks for the web site info.
Norm
