Old 06-08-2009, 08:25 PM   #1
want2be
Default help
#1 i have picked up a 69 camaro, has a roll bar welded in and the front clip is also welded to connectors to the roll bar. problem is the wheelbase is 108.16 on the left and 109.00 on the right. any ideas? does the 3/4 inch rule still apply, do you run an unequal wheel base?
#2 how much of the engine in stock (1969 bbc) is stock-not aftermarket parts-if i just started with the block, heads and crank would i be correct in assuming that the correct aftermarket parts are available? thanks in advance
want2be is offline   Reply With Quote
