Old 06-01-2009, 11:18 AM   #1
sst1226
sst1226's Avatar
Liked 11 Times in 2 Posts
Default Mufflers and Evac/Crankcase Venting
Does anyone run Dynomax Bullet Mufflers right off the collector with an Evac system? I tried running the Moroso Spiral Flow Mufflers and had issues with the motor pushing oil out through the dipstick tube. I bought the Dynomax Bullets because they seem far less restrictive.
Mario DiTeodoro III SST/SG1226 STK126M
sst1226 is offline   Reply With Quote
Old 06-01-2009, 01:54 PM   #2
SCOTT SST2871
Default Re: Mufflers and Evac/Crankcase Venting
I ran that same setup for years with no problem,but i now run a vacuum pump because i run alcohol.it should work fine! Scott fifield
SCOTT SST2871 is offline   Reply With Quote
Old 06-01-2009, 02:54 PM   #3
Bryan Gillespie
Banned
What's a muffler ??
Bryan Gillespie is offline   Reply With Quote
Old 06-01-2009, 04:37 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 857 Times in 234 Posts
Originally Posted by Bryan Gillespie View Post
What's a muffler ??
Something that made some manufacturers a lot of money a few years ago! ....Mine have been gone since a baffel came out at Atco and cut a new slick in the traps. ..........Vacuum pump is WAY more effective than the best working evac system, especially with mufflers. Probe placement in the collector is CRITICAL..........Tom
Old 06-01-2009, 05:51 PM   #5
Michael Pliska
I used to run mine with Supertrapps, but with big spacers added between the discs (so they may as well have been open headers). My new headers (I just finished building) have them, with the 4" ID Dynomax bullet mufflers. Hopefully I'll get to find out if it works sometime soon.
Regards,
Michael Pliska 643 S/G
Michael Pliska is offline   Reply With Quote
