Old 05-22-2009, 06:24 PM   #1
Philip Saran
Liked 14 Times in 11 Posts
Default Line Locks Revisited
OK, I already know how to plumb the line lock, but my question is
how many of you use it to lock the front brakes vs deactivating the
rear brakes for your burn out and why did you choose that option??
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 05-23-2009, 06:36 AM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Line Locks Revisited
this is a new method to me, never heard of "blocking" the rear? How, why would that be done?
Larry Woodfin 471W
Old 05-23-2009, 07:48 AM   #3
Kegracing
OK, just taking a guess here, have not tried this, but kind of interesting.
I am guessing they are using the solenoid to block pressure from rear brakes when button is pushed. This would allow you to use or drag front brakes to do a rolling burnout... not sure why you would do this unless in a class you could burnout out over the line, or you were just doing a show or burnout contest type deal...
Is this the set up you are discussing and can I ask why?
Ken
Kegracing is offline   Reply With Quote
Old 05-23-2009, 11:22 AM   #4
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
We've always installed it to lock the front brakes.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 05-23-2009, 11:54 AM   #5
Rob Petrie E395
Liked 216 Times in 77 Posts
One other thing to think about on this. If you block the line going to the rear brakes with a line lock solonoid the piston in the master cylinder is not going to want to move since the fluid in the line would build pressure very fast with little pedal movement, therefore making it very hard to build pressure in the front brakes. Also if you can build pressure you would have to hold your foot on the brake pedal during the burnout to maintain it. If you want to do a rolling burnout why not just set the brake pressure lower with the line lock on the front (ie if you usually set it at 800 just use 400 or whatever works for you) so the car will still roll a little bit when it comes out of the water box.
Old 05-23-2009, 08:21 PM   #6
Philip Saran
Thanks for the comments. I have always seen it done the "normal"
way of locking the front brakes.
But Bob Mazzolini recommends using it to lock out the rears so
you can do your burn out and just use the brake pedal to control
speed with the front brakes. This is how he has his SS/AH car
set up.
Phil Saran
Parker, Colorado
Old 05-23-2009, 08:58 PM   #7
George Mirza
I could be wrong on this, but wasn't the line loc originally designed to hold stick shift cars from rolling on the starting line by holding pressure to the front brakes.
Phil stick to using them on the front, who knows what kind of exotic brake setup that AH car could have on it.
George Mirza is offline   Reply With Quote
Old 05-23-2009, 09:53 PM   #8
Philip Saran
George that is exactly what I'm going to do.
But I have seen Mazzolini's Hemi Cuda up on the lift and the line lock is plumbed
in the brake line running to the rear. I guess he uses it so the rears are unlocked
and you just do a burn out and then stop with the front brakes.
Mine will be plumbed for the fronts only.
Phil Saran
Parker, Colorado
Old 05-26-2009, 07:22 AM   #9
mike natoli
mike natoli's Avatar
Liked 51 Times in 16 Posts
Cool Re: Line Locks Revisited
very interesting... look like a pro stocker doing a burn through very cool... SS/AH cars can go past the starting line on their burn out? Or is this when they are just competing in the Hemi challenge?
mike natoli is offline   Reply With Quote
Old 05-26-2009, 08:18 AM   #10
M Cotten
I was told at a teardown years ago in Memphis that is illegal to have the line loc on the rear brakes. Even though I was using it as you described Phil, I believe the concern was that people would lock the rear wheels when staging and leave by releasing the button..
Mike
M Cotten is offline   Reply With Quote
