Old 05-14-2009, 02:40 PM   #1
sst1226
sst1226's Avatar
Liked 11 Times in 2 Posts
Default Powerglide vs. TH350
I have an iron-headed 396 that makes around 500hp in a 3050lb, Nova. Right now I'm running a Glide with a stock case stock gear and upgraded internals (kevlar bands etc.) I was thinking about going to a 3-speed, possibly a Th350 since I heard that I wouldn't have to change driveshafts or crossmembers. Is this true? If so, what do I need to make a 350 trans live in this car?
Not neccesarily looking for the most lightweight internal parts that use the least amount of hp, just want to know what needs to be done to these transmissions so that it will hold up. I also normally launch the car off the transbrake with a 5,000 stall converter and it has a turbo spline so I would be using the same converter.
Mario DiTeodoro III SST/SG1226 STK126M
sst1226 is offline   Reply With Quote
