Old 05-13-2009, 12:33 PM   #1
Jason Leindecker
Jason Leindecker's Avatar
Default MSD Crank Trigger w/ Accel DFI 7 on LT1
I have just added a Crank trigger, 6al, and coil to eliminate previous problems with the MSD Lt1 distributor. I disconnected the distributor and only have the coil wire going to it. I have plenty of spark at both the coil and the plug. Now i dont have fuel ( i have 60 lbs of FP @ regulator). I am assuming the DFI needs a signal from the ignition to fire the injectors (batch fire). If so how does this get wired.
Thanks
Jason
Jason Leindecker
Jason Leindecker is offline   Reply With Quote
