Old 05-12-2009, 11:48 AM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default manual trans ratios
Let me hear about your four speed manual trans ratios.
My application is local brackets in a 3050-pound door car. The engine is an LS series small block, 372 C I. Sweet spot range for the engine will be about 5400 – 7200 RPM. I estimate the engine will be about 525 – 535 horse; performance will be low 10’s.
Rear tire will be 29 X 11, rear gear 4.88
I plan to use a Rob Youngblood Advance Clutch system and a G Force, four speed.
Thanks
Larry Woodfin
Larry Woodfin 471W
