Go Back   CLASS RACER FORUM > Stock/Super Stock Associations > Can-Am Stock Super Stock Series
Old 05-11-2009, 09:22 AM   #1
dragracer502
dragracer502's Avatar
Liked 10 Times in 8 Posts
Default NEW CLASS : Looking for Interest / Comments
Class Proposal:
OUTLAW STOCK
This is a proposed class to be included in competition with the Can – Am Stock Super Stock association.
ALL NHRA and IHRA safety and competition rules applying to stock and crate motor classes will apply, with the following changes:
1.Only SMALL BLOCK motor combinations will be accepted
2.Motors MUST be manufacture available (NO aftermarket blocks allowed)
3.Any OEM cylinder head casting is permitted ( no limit on head machining, valve size)
4.A MAX of 0.60 over bore is allowed on any factory engine Cubic Inch.
5.Any corporate available transmittion is permitted. NO trans-brake allowed.
6.Any corporate rear housing is permitted, STOCK width for body style used MUST be retained. (Ladder bar rear suspension is permitted)
7.ONE power adder (turbo, Nitrous, Super charger) is permitted. * In the case of engine combinations that are OEM with any one of these power adders, NO additional type of power adder may be in place. OEM turbos / super chargers are NOT required.
8.All entries will run at B stock eliminator weight.
9.Cars will run heads up on a .400 Pro Tree
PLEASE SIGN BELLOW IF YOU ARE INTERESTED IN COMPETING IN THIS CLASS FOR 2010.
dragracer502 is offline   Reply With Quote
