Old 05-05-2009, 01:22 PM   #1
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default P.G.cooler
My son has a power glide in his car, new this year last weekend trans temp went high 235 after many rounds of racing. He has 2 coolers on this run in series, when it got hot he said he felt 1 cooler line was hot the other was cold, also both coolers were cold. This week he pulled both lines off the trans and started engine he tells me fluid is coming out of both lines, any ideas? this does not seem normal to me. Joe
Joe Buchanan SS/BX 3117
Old 05-05-2009, 01:41 PM   #2
Henry S
Liked 19 Times in 7 Posts
Default Re: P.G.cooler
where are you taking temp. readings from? the pan or the cooler line? those can be a big difference. pan temp. is the better location.
Henry S is offline   Reply With Quote
Old 05-05-2009, 01:57 PM   #3
buzzinhalfdozen
Temp probe is in trans pan, cast alum. I guess what concerns me most is pressurized oil at both cooler lines this makes no sense to me. Joe
Old 05-05-2009, 01:59 PM   #4
Adger Smith
Liked 880 Times in 311 Posts
Joe,
You have a PM
Adger Smith (Former SS)
Old 05-05-2009, 04:07 PM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
It's likely the cooler bypass valve in the pump is either stuck open or missing . .....That would allow fluid to flow from both lines. .........misaligned shaft sealing rings or damaged rings can cause a loss of cooling circuit pressure,making it difficult for the oil to have enough pressure to flow thru 2 coolers. .......Tom
Old 05-06-2009, 07:01 AM   #6
buzzinhalfdozen
Thank you for the replies, we'll be looking into this later this week. Joe
