Old 04-19-2009, 09:46 AM   #1
NHRA 5037
Default front shock mount picture
I run the QA1 R series shocks in the front of my GM A Body car and I am in the process of changing the lower shock mount to keep the shock off of the spring. There was a picture posted on this site about 6 months ago where someone mounted the shock under the control arm. I searched the site every which way but cannot find it. I would appreciate it if some could repost it.
Thanks!
NHRA 5037 is offline   Reply With Quote
Old 04-21-2009, 07:16 AM   #2
SmallBlockNova
SmallBlockNova's Avatar
Send a message via AIM to SmallBlockNova
Default Re: front shock mount picture
That's Brian's modification..
SmallBlockNova is offline   Reply With Quote
Old 04-21-2009, 11:27 AM   #3
blasttime
blasttime's Avatar
Disc brake bleeder screw?
blasttime is offline   Reply With Quote
Old 04-21-2009, 03:02 PM   #4
reera
Liked 31 Times in 6 Posts
There are four bleeders on Wilwood calipers. One on each end of the outside and inside of the caliper. Just bleed the one's on the top and you're fine.
Ryan
reera is offline   Reply With Quote
