Old 04-16-2009, 09:05 AM   #1
Gear Jammer '94
Guest
Posts: n/a
Default '94 Camaro Stocker front suspension question
I have my front suspension completely torn apart. I see companies like Global West make the lower control arm bushings and you can also get performance ball joints from FJ Smith or Afco. Of course I'll replace the struts and springs but what about the uppers? Also, are any of the lower parts better than the others? I'm building a S/GTB small block car with a Jerico. Thanks.
Old 04-16-2009, 07:29 PM   #2
Cam
Cam's Avatar
Default Re: '94 Camaro Stocker front suspension question
I just installed Global West upper and lower part in my '94 Camaro Stocker. Everything fit well, no surprises. The suspension now moves with one finger.
Cam
Cam is offline   Reply With Quote
Old 04-17-2009, 08:30 AM   #3
Gear Jammer '94
Guest
Posts: n/a
Thanks Cam. Boy, that would be much improved over stock! Did you use their upper and lower ball joints as well or should I get pick some up at Napa? Didn't know if there was a performance advantage there too. Thanks.
Old 04-17-2009, 07:27 PM   #4
Cam
Cam's Avatar
The stock upper A arms would hardly move with the shock and spring out, very tight. The lowers were only a bit better. I used the GW ball joints but I thought I read there was a low drag version available elsewhere.
Maybe someone can jump in with the details.
Cam
