Old 04-15-2009, 06:04 AM   #1
rodrocket
Default Lamb Struts - Wheel Bearing Help
greetings All
can anybody help me with some info in relation to the correct bearing & seal to run on my car
it has Lamb struts ( Anglia ) & i have just purchased a new set of front wheels ( Alumastar 788-15000 ) Anglia
the issue i have is Lamb list "SPECIAL" bearings for this application
the bearings that come with the new wheels are as follows
Inner Race: 4T - 07204 - NTN
Inner Bearing: 07097-544
Outer Race: 03162 HP
Outer Bearing: 03062
Seal is Timken boxed with the part number of 471795 however the seal is marked "NOK AD7127E"
what i need to know is, Do i need to buy
A: The Lamb "Special" set
B: the 07098 Bearing
C: the C-R (Chicago Rawhide) 12565 SEAL
D: Use what i have been supplied with the wheels
the above two part numbers i have found through different forums
regards
rod
rodrocket is offline   Reply With Quote
