Old 04-14-2009, 09:57 PM   #1
Robert Pare Racing
Robert Pare Racing's Avatar
Liked 2 Times in 1 Post
Default Sway Control question
I have a Motorsport trailer 28' triple axle that has 3" wide x 5" tall A frame members..any recommendations for sway control?..I have the HP Reese trunnion setup now, and not sure if the old friction style is worth a hoot, or should I just go with the Dual Cam setup...With the stocker or a dragster in the trailer it's kinda bad with sway..the Cutlass doesn't seem near as bad, I guess 'cause it's got a BBC in it. I would have to weld the "pieces" to the frame in lieu of using the U Bolts supplied..I'm trying to avoid that.
It is my understanding that the Reese setup is for 2 1/2" wide frame members, not 3"..anything on the market that is the new hot lick?
Rapare-Racing.com
Robert Pare Racing is offline   Reply With Quote
Old 04-15-2009, 09:13 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 852 Times in 234 Posts
Default Re: Sway Control question
Rob, My experiance is the dual cam is much better than the friction bars. .. ..I can barely feel my triple axle 26' Goldrush move behind the motorhome except on the worst of days........Are you still towing behind a coach? ......For a pickup or Suburban, I'd highly recommend a PullRite hitch. ....It moves the pivit point of the trailer to just behind the axle housing, eliminating the leverage the trailer exerts on the normal rear overhang. .....I had one when I towed with a Suburban, had a 30' triple axle Haulmark behind it ,and it was effortless, almost like towing an open trailer! ...Tom
Old 04-16-2009, 06:36 AM   #3
Robert Pare Racing
Thanks Tom..I still use the Coach on occasion, but I also have a 2500HD Duramax that I use for bracket racing which does extremely well..My Silverado SS on the other hand, not so good..The motorhome setup has the trailer swaying like crazy..all my other trailers behave without all the sway control..I had pretty much decided to order from Camping World the dual cam set-up, but I thought I'd jump on here first just in case there was something else on the market that was new, groovy, and out of sight. You class guys are always keeping up with what's current. Cheers.
Rapare-Racing.com
Old 04-16-2009, 08:12 AM   #4
BlueOval Ralph
Banned
Check out a Hennesy not sure of spelling they adv in Trailer Life Mag
from everything I have ever heard they are first class But alot of $$$$$
BlueOval Ralph is offline   Reply With Quote
Old 04-16-2009, 08:15 AM   #5
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Robert....Your old trailer tows like a dream and I do use the Reese dual cam sway control and have for 20 years. I highly recommend it......I've had one since day one with an enclosed trailer. Doorcar, dragster, suburban, pickup truck.....it works and sway is non-existant.
Rich Biebel
S/C 1479
Stock 147R
Old 04-16-2009, 01:49 PM   #6
Chaserfan Fan
Chaserfan Fan's Avatar
Robert , used both types on 28 ft Hualmark . Cam locks MUCH MUCH better.
Chaserfan Fan is offline   Reply With Quote
Old 04-16-2009, 03:51 PM   #7
BlueOval Ralph
Banned
www.hensleymfg.com
810 410 6580
Secure Online Safety
Shop Online Here or Contact Us at 1-800-410-6580
