Old 04-05-2009, 01:29 PM   #1
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Problems with Paging Altronics Weather center
Anybody have any suggestions on what could be wrong would be great. I went to first race of the year at Gateway this weekend and my pagers wont recieve pages if I am more than about 50 yards from the trailer. I have cleaned all the connections and the ground plane. Seemed like it was working fine when I checked it this spring I could get pages almost a mile from the house. I know I can call them in the morning but untill then its driving me nuts!
Old 04-05-2009, 07:01 PM   #2
Bill Grubbs
Liked 564 Times in 66 Posts
Default Re: Problems with Paging Altronics Weather center
Sounds like a bad connection in the antenna cable. Make sure the coax ground and signal wires are making a good connection with the connector. I would check the continuity of each. Also, are you using a battery, or a wall power adapter? If you are using a wall adapter try a battery (fully charged auto battery), you could be trying to pull to much power.
Bill
Bill Grubbs is offline   Reply With Quote
