Old 03-27-2009, 10:36 AM   #1
67champ
Liked 4 Times in 2 Posts
Default Scaling F-Body GM
Can someone explain to me what the purpose is in what I think they call "scaling" a drag car? I am asking about the process of weighing each four "corners" of the car, and making each "corner" a certain weight or percentage.
Is this something that a person would do to a leaf spring camaro or firebird? If so, what would be the proper percentage of weight per corner, etc.?
THANKS!
67champ is offline   Reply With Quote
Old 03-27-2009, 02:40 PM   #2
63corvette
Liked 358 Times in 103 Posts
Default Re: Scaling F-Body GM
Scaling a car is to setup the suspension to plant the rear tires and go straight on the launch.
It can be done with the four link or ladder bar suspension. It also allows you to keep the front end square with the front wheel equally loaded on the launch which will keep the car straight.
I am not sure how anyone would do it with a stock suspension.
With a good set of scales you can setup a car in the garage and have it ready to race as far as the suspension is concerned before every taking it down the track.
My 2 Cents
63corvette is offline   Reply With Quote
Old 03-27-2009, 03:08 PM   #3
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Yep, Stocker's do it too. done with you in car, balance weight and move as much to the rear as possible.
Bob Pagano A/SA
Old 03-27-2009, 06:10 PM   #4
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
Scaling is very helpful if you just built a new car, or it has been in storage a long time, or in a crash. It can save a lot of time if it pulls to one side as well.
If you install a stiffer spring in the left front, the wheel weight of the right rear will increase. The opposite corners effect each other, no matter what type of suspension.
Also, the preload adjustment on Caltracs have an effect as well.
I had King Race Cars scale my 69 Camaro a couple years ago. He heated and bent one front coil to get the rear wheel weights about equalized. I'm sure that I recorded the corner weights in that year's log book. If you are interested in knowing the numbers, send a PM, and I'll dig out the books and try to find the info.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 03-28-2009, 07:49 AM   #5
bob gonier
Yes It will/does but Calvert doesn't recommend doing so.
bob
bob gonier is offline   Reply With Quote
Old 03-30-2009, 04:24 AM   #6
67champ
Thanks for the replies everyone!
dt
Old 04-02-2009, 09:36 PM   #7
Tony Curcio
Off the trailer the corner weights were as follows:
LF- 956 RF- 910
LR- 811 RR- 706
After raising the LF spring rate 50 lbs, the rear wheel weights were about equal, then the Cal-Tracs were re-set according to mfr instructions:
LF- 1006 RF- 863
LR- 756 RR- 772*
*16 lbs preload
Old 08-13-2013, 09:54 PM   #8
Pistol Pete
Pistol Pete's Avatar
Liked 782 Times in 210 Posts
LF- 956 RF- 910
LR- 811 RR- 706
LF- 1006 RF- 863
LR- 756 RR- 772*
*16 lbs preload
Why would you want 143lb. difference between LF & RF ????
I'm guessing the driver is in the car with these wt. numbers ??
"Pistol" Pete Dutko
Old 08-13-2013, 11:43 PM   #9
Tony Curcio
Yes, 220 lbs in the driver's seat. The front weights are not critical on a drag car. The object was to get some balance on the drive tires.
Old 08-14-2013, 02:12 AM   #10
Pistol Pete
OK Thanks Tony.
"Pistol" Pete Dutko
