Old 02-21-2009, 03:08 PM   #1
RJ
Default Stocker front tires
I am building a 3600 lb. stocker, and If my only concern is getting the quickest ET possible, which front tire should I use and at what pressure?
I'll make room for any tire and buy offset wheels if I need to.
Thanks
RJ is offline   Reply With Quote
Old 02-21-2009, 10:23 PM   #2
RPM5595
RPM5595's Avatar
Liked 32 Times in 14 Posts
Default Re: Stocker front tires
The tallest tire you can fit will give you the most rollout and a longer "run" at the beams. Pressure wise, depends but I used to run 30psi. in my 28 tall M/T's. Hope this helps. Jay
Jay Roeder
facebook.com/racefuelsales
Former N/SA , Soon to be SS/AS, Renegade Race Fuel dealer
RPM5595 is offline   Reply With Quote
Old 02-22-2009, 01:40 AM   #3
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
It wont make much difference at all. Choose the right tire for you to get a light and run it!
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 02-22-2009, 03:55 PM   #4
treessavoy
Liked 4 Times in 4 Posts
I've always run a tall tire at about 30lbs but I stage shallow, if you stage deep or roll into the lights you should try a shorter tire. Varying the tire pressure can effect your reaction times.
