Old 02-08-2009, 04:16 PM   #1
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Question Header 2 trans issue?
Hello! well i put the new header on the the pass side no trouble 1/2 hr i'm in their now then the driver side! well...i have an issue/? the header hits the shifting linkage...well the cable where it goes onto the trans. my question is can i move the linkage/cable to the inside( between the shifting arm on the trans & the pan)? it looks like i can but with no one here to help me i can't tell because i can't move the shifter & look @ the linkage @ the same time...has anyone else run into this? Thanks guys
Old 02-08-2009, 05:42 PM   #2
ZASKO
Talking Re: Header 2 trans issue?
greg, hook it up and it should work fine, just make sure it goes into park ok and holds, then the others will be ok. go for it jimmy zzzzzzzzzzzz
ZASKO is offline   Reply With Quote
