Old 02-02-2009, 07:27 PM   #1
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Question Olds exhaust gasket?
Dose anyone make a copper exhaust gasket 4 an olds?
Old 02-02-2009, 07:58 PM   #2
Liked 1,874 Times in 422 Posts
Default Re: Olds exhaust gasket?
Greg, have you looked at the Cometic website? They may have an MLS style exhaust gasket. I didn't have the greatest luck with those embossed copper gaskets, on anything. I'll tell you what did work though. I used the Mr. Gasket Ultra Seals, and I sprayed them with that dry film moly spray. I've been using that stuff on good gaskets, they don't stick, and you can reuse them a few times.
Old 02-02-2009, 09:07 PM   #3
JRyan
Liked 112 Times in 31 Posts
Greg,
Mr. Gasket #7170 from. Also available in aluminum; #7170A. The seal depends on your header flange. Ours work just fine (over & over), and are far superior to the Ultra-Seals which burn out the middle of the center ports.
Jerry
Old 02-02-2009, 09:49 PM   #4
greg fulk
greg fulk's Avatar
Thumbs up Re: Olds exhaust gasket?
That's why I was asking...went to put the new headders on & both sides had the middle burned out! It was Dads idea to go with a copper gasket. THANKS 4 the help guys! oh P.S. new headders are Heddman that I had some custom work done to.
Old 02-02-2009, 10:40 PM   #5
STK1217
STK1217's Avatar
Liked 10 Times in 7 Posts
Smile Re: Olds exhaust gasket?
Greg try MAXX Performance #170 solid copper exhaust gaskets.
STK1217 is offline   Reply With Quote
Old 02-04-2009, 01:08 AM   #6
Run to Rund
Liked 54 Times in 27 Posts
Another option is Remflex, some sort of graphite fiber, supposed to seal well and hold up.
