Old 01-31-2009, 08:19 PM   #1
trmnatr
Default ARP / Milodon Question
In the past i have used Milodon Main studs when using their splayed main caps
I have not used their studs in a while, with the Economic situation now days i dont know if they have switched material or if the quality of their studs have dropped
Has anybody used Milodon Main Studs recently ?
Im thinking about using the Milodon Main Studs on our new 406 thats using their splayed main caps
I dont know of an ARP stud kit that will work as Milodon caps use a different length stud/bolt so you have too use their stud/bolt. The cap kit comes with 8740 bolts, may just end up using them bolts as we have used their bolts recently
Does anybody know an ARP main stud part number that works with Milodon Caps ? I only need then for the inner 2 bolts on the 3 centers and front and rear cap. The Milodon cap takes longer than std studs
ALSO, ON A SUPER STOCK GT/JA ENGINE, CAN YOU USE MILODON SPLAYED MAIN CAPS ON AN 010 BLOCK ????
trmnatr is offline   Reply With Quote
