Old 01-30-2009, 09:00 PM   #1
BLIND MULE
BLIND MULE's Avatar
Default 460 Fox Body with stock hood???
Got an 84 LTD Wagon wanna put in a 460 and keep stock hood any suggestions? I have seen Mustangs done but how in the world do you do it?
Thanks!!!!!
BLIND MULE is offline   Reply With Quote
Old 01-30-2009, 09:22 PM   #2
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
Default Re: 460 Fox Body with stock hood???
Thanks!!!!!
I put a 460 in a 79 Fairmont. I believe the hoodline is the same as your 84 LTD. You will probably need 1 1/2 inch k-frame spacers. There is a guy named "Bob" on www.460ford.com that sells those spacers. Just type in K-frame spacers in the search function. It's a start.
Should be no problem gettin it to clear the hoodline with spacers that big.
On my 87 Turbo Coupe 460 I used a Ford Van C-6 transmission rubber mount to lower the rear of the trans to help with the crank angle when I lowered the engine.
You can also order steering rack offset bushings to lower the steering rack a bit more. Of course custom engine mounts will get you a bit more as well.
I had to use a solid Flaming River steering shaft to get more exhaust clearance because the engine sits lower.
Hope this helps.
Alan
