Liked 11 Times in 5 Posts
Who is the best builder for a Super Stock Thermoquad ? Will it make any difference having a -8AN line going into as opposed to a -6AN line ?
Thanks |
I'm curious also... they are by far the most tempermental things I have ever seen!!!
Bub Whitaker |
Liked 138 Times in 51 Posts
I haven't dome any business with him, but he is well known on the moparts.com web site:
http://www.thermoquads.com/
LOCOMOTION Racing |
Thanks Myron, but I need Racer testimonal as to who they used and I think JC is lookin for this info also. I've done 3 in house, one for shop test on customers engines and two for engines wev'e sent out the door for customers. All of them have been a challenge, hours to do, findin parts and then multiple pulls on the dyno to set air fuel, butterfly angles, air door shape and setting. All the ones my customers have come up with we need to fix... Someone out there must know...
Bub Whitaker |
Liked 4 Times in 2 Posts
I have #8 on my superstocker and #6 on my stocker, really don't see any difference either way...steve wann has had Brad Vanlant do a couple carbs, says he is pretty good with them.
So is Brad Vanlant an individual who does this for a livin or a side line and how do we get in touch with him?
Bub Whitaker |
I dont' think he does them for a living! he races stock elim.. ill see Steve Wann in a couple days on my way to Pamona, i will check with him.. I believe Brad lives in the Midwest..
Steve Wann is good with TQ's. Angelo Phillips and I have been doing our own based on Steves original blueprint and have had good success.Jack Foshee is also really good with them also.we do away with the metering rod setup and run holley jets and a few other tricks.Right now we are testing to see wether the side inlet or the bottom inlet is better for fuel feed. and we have been using -6 line with a bypass system.Also use a good air cleaner.my company sells a single 4 copy of the fresh air style unit the works killer.
#9 | |
Bub Whitaker |
I don't want to say ive Mastard them, but ive done a pretty good job,, learning from Steve Wann, Bill Bushmaker, and a few other's... i guess ill know in about 7 days when i make a pass @ Pamona.... i just built a new one for my stocker.. I have a good back up that Marlin Bogner had done for my superstocker. so i guess if the new don't work it's back to plan B
