Old 01-26-2009, 12:28 AM   #1
7423
Default MSD and timing question
Installed a MSD 6AL and a 2 step in my very stock 1994 Mustang 5.0. Checked initial and total timing before the install. I now have 10 degress more initial and 10 degress more total after the install and never touched the distributor. I have always used a "dial type" timing light. After checking the MSD tech forum, I have read that MSD says not to use that type of light. They suggest a plain jane, no frills light and using an alternate power supply. If my light is the culprit, why does it work properly with a 6AL? I have owned this light for many years and have never had such a problem with it.
Charlie Allen
7423 is offline   Reply With Quote
Old 01-26-2009, 10:06 AM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: MSD and timing question
Well I'm certainly no expert on this subject however it could be something as simple as the MSD is triggering on a different part of the signal or (pulse). Some systems trigger on the rising pulse and some trigger on the falling pulse. The fact that you gained 10 deg. across the board would tell me that the MSD is just triggering at a different point of the ignition pulse. just my opinion Joe
Joe Buchanan SS/BX 3117
Old 01-26-2009, 10:57 AM   #3
63corvette
Liked 359 Times in 103 Posts
I know for a fact there is a 10 degree difference between the 6AL and the 7AL boxes.
When having a problem with the ignition on my car which had a 7AL I borrowed a 6AL from a friend and when checking the timing it was exactly 10 degrees different from the start.
It has been a couple of years ago so I do not remember which way the 10 degrees was fast or slow but I do remember it was exactly the 10 degree difference.
Don't know if that helps but good luck with the fix.
My 2 Cents
63corvette is offline   Reply With Quote
Old 01-26-2009, 12:18 PM   #4
John Mason
Talking Re: MSD and timing question
There is a 10 degree difference using the 7 series boxes. The fix for this is cleverly hidden in the instructions, where it says "timing must be reset after installation".
John Mason 7743 SS
John Mason is offline   Reply With Quote
Old 01-26-2009, 12:45 PM   #5
partsbob67
Liked 79 Times in 11 Posts
damn 2 steps any way. you don't need that crap charlie, just something else to break!!!!!!!!!!! how's that hot rod running anyway? hope to see you in a couple of months in fontana.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 01-27-2009, 09:14 PM   #6
7423
Working on it Bob, lots of hours. Running brackets and developing a relationship with my new horse. Hopefully I will be ready by Fontana.
Old 01-29-2009, 11:56 AM   #7
partsbob67
go man go.
bob beals 7244
Old 01-29-2009, 04:25 PM   #8
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
I'm using a dial light and mine bounces around.
Floyd Staggs 787 SST
