Old 01-15-2009, 07:04 PM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default TH350 Blowing Fluid
Towards the end of the 2008 season I went to a deeper gear spinning the engine/trans a little higher. Now I have a problem of transmission fluid blowing out of the plastic vent in the case. I see that TCI offers a reservoir for this problem on a TH400 or Glide but not for the TH350. Also, I remember seeing a super comp rail that had the vent line plumbed into the pan with AN line (aftermarket case).
I would like to just run a line from the vent to the pan, but I am not sure if this will fix the problem since any transmission case pressure will then have no way (that I know of) to release.
I am open to any ideas to keep my under carriage and garage floor clean.
Thanks,
Chad
Chad E532 is offline   Reply With Quote
