Old 11-30-2008, 12:42 PM   #1
Bob
Default Turbo 200
Who sells parts to build a TH200 transmission? In particular, who sells a valve body? I know Turbo Action does, but is there anyone else?
As far as the valve body goes, which is better, forward or reverse pattern? With the band apply in second, a reverse pattern would not allow you to neutral the car on the top end.
Bob is offline   Reply With Quote
Old 11-30-2008, 11:08 PM   #2
Default Re: Turbo 200
What would be the problem with using a Turbo Action valve body?
Old 12-01-2008, 12:02 AM   #3
Bob
No problems that I know of, but that is why I am asking.
I do know there are alot of reverse pattern and auto shift valve bodies in use. And the fact the Turbo Action does not offer these would suggest that there are better valve bodies on the market.
Old 12-01-2008, 12:29 AM   #4
I'm pretty sure Paul sells an automatic upshift deal.
I've built about a dozen forward pattern 200's with the TA valve body and never had any trouble with one of them. Good product, from a good guy who knows his stuff.
