Does anyone make a good double adjustable shock for the front of a 66 chevy II that will fit the stock mounts? I just purchased a pair of Afco's that don't fit. What are the super stock guys using for these cars, and do you have to run the factory spring, or can you convert it to a coil over set up with the stock upper a-arm? Any help would be appreciated!
4878 SS/GA 66CHEVY II |
Liked 1,436 Times in 299 Posts
You cannot do a coilover converstion, but don't pitch your AFCOs yet.
Call this guy. He makes a mount for the bottom of the shock. http://www.matukasmotorsports.com/index.html
James Schaechter 3163 STK |
Thanks James, I'll give him a call. The problem with the afco is the bottom adjuster on the shock makes the overall diameter of the shock to large to fit inside of the factory spring. What shocks do you run on the front of your car? Thanks
4878 SS/GA 66CHEVY II Last edited by Darrin Christen; 11-22-2008 at 04:38 PM. |
Liked 9 Times in 3 Posts
send me an email address and I can tell you what Afco number it is for the part that will make it bolt on without a problem...
http://proheadersystems.com/gallery/...ns+duece&id=53 info@proheadersystems.com |
I found the part # and its a part you can get from Afco. Email me and I will send it over. Also I will explain how we got the car to sit this nice and also work as well....
info@proheadersystems.com 402.438.0430 Chassis1 |
Guest
Posts: n/a
What brand of front coil springs are you using?
moroso trick springs
