Old 11-20-2008, 08:09 PM   #1
RCM426
Question Rear Slicks for stocker
What slicks would be good for a 76 NOVA running I/SA will need news ones for next seasons but looking now thanks Rich
e mail RCMBASS@AOL.COM
RCM426 is offline   Reply With Quote
Old 11-20-2008, 08:37 PM   #2
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Rear Slicks for stocker
I've had good luck with Hoosier. Bias ply are good for consistency. Radials will pick up some ET, but are more sensitive to marginal track conditions. In other words, they'll spin a little easier if the track isn't in good shape. They have standard and lightweight versions. Also, a radial will not grow like a bias ply, so your rpm's will be higher at the finish if using the same size tire. Put the 9" tires on 10" rims if you can find the correct offset. Holeshot wheels provides a wide variety of offsets & styles. www.holeshotwheels.com
LOCOMOTION Racing
Old 11-21-2008, 03:38 AM   #3
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Wink Re: Rear Slicks for stocker
I've run both M/T & Hoosier...the Hoosier seem to be better on the "not so good" tracks but the M/T are quicker on a good track. If your going to run on Div. or National event tracks the M/T works great but if your going to brackets race too on not so good tracks go with the Hoosier...their a gum ball!
