Old 11-06-2008, 03:25 AM   #1
HQS
Default Muncie trans help
Can somebody tell me if the shift fork shafts that go through the muncie side cover can be changed from the ones that have a stud to the ones that use a bolt to hold the shift arm on? I exchanged the ones with a stud for the ones with a bolt with a friend who was restoring a 66 nova. When I tighten the shift arm down, it binds on the sidecover and won't move. Is there a difference between the two shafts.
Thank you,
HQS
HQS is offline   Reply With Quote
Old 11-06-2008, 10:06 PM   #2
REGGIE WINKLES
Liked 39 Times in 9 Posts
Default Re: Muncie trans help
HQS,
The 64-68 Muncie used the "stud/nut" set up the 69 and up used the "bolt on"
shift levers. Be sure you don't have a mix/match deal going on there with the shift forks
and side cover. I bet that is your problem. I hope this info helps and always remember
"shift happens".
Good Luck, Reggie
Reggie Winkles 2650/Stock
REGGIE WINKLES is offline   Reply With Quote
