Old 11-06-2008, 12:31 AM   #1
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
Default Round Tubing vs Square Tubing
Have any of you racers lost any weight redoing your car, goin from Sq tubing to Round Tubing? How much weight did you lose? Is there any weight reduction at all goin from Sq tubing to Round tubeing? Also I would like to why there is a weight reduction if this is true? thanks classracer
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 11-06-2008, 10:04 AM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: Round Tubing vs Square Tubing
Unless you are going to go from mild steel to chromemoly tubing the weight savings will be extremly small. ............When you go to CM tubing the wall thickness can be slightly smaller on the box tube, depending on the chassis spec you are building to. ........058" box vs. .083" for tube.......I'm assuming you are more concernad with the tail section of the chassis,and not the frame connector area. ......Every builder has a preference ,altho some cars lend themselves more to one or the other. .....If I can find it I'll post a link to a site that has charts with all the weights per foot of various size tubing. .......TOM
Old 11-06-2008, 01:43 PM   #3
thank you Tom, I'd appreciate it
Old 11-06-2008, 03:21 PM   #4
Tom Goldman
http://tottentubes.com click on stock list for the engineering data
