Old 11-04-2008, 09:25 AM   #1
herbjr
Liked 83 Times in 32 Posts
Default What Tire to run
What tire would you run on a Modified Type car running 5.80 at 3000lbs. Its a small block automatic.
Herb Jr
herbjr is offline   Reply With Quote
Old 11-04-2008, 11:08 AM   #2
Dave Goob Cook
Dave Goob Cook's Avatar
Default Re: What Tire to run
Probably a M/T 14-32 stiff sidewall.
"Despite the high cost of living, it remains popular."
Dave Cook
NHRA N375
Dave Goob Cook is offline   Reply With Quote
Old 11-04-2008, 08:35 PM   #3
buzzinhalfdozen
Liked 11 Times in 8 Posts
Herb I agree with Dave on this My car is 2960# and with a " normal" tire without the stiff side wall it wants to run over the tire unless we ran the pressure way up 11-12 psi. Next year I will be trying Radials for the first time however when I get new bias plys they will be with the stiff sidewall. For reference 9.75 et @ 2970lbs. 7500 rpm chip 8100 rpm stall converter. Hope this helps Joe Buchanan SS/AX SS/BX 3117
Old 11-05-2008, 08:59 AM   #4
buzzinhalfdozen
Ray, My new car is an auto. trans. Joe Buchanan
Old 11-05-2008, 09:26 AM   #5
herbjr
347 in motor, 5.67 gear, 8800 rpm....3 speed, oh yea its a dodge. It ran 5.90's. its a legal bore and stroke 340 for ihra production ss but will run c/m or bs. on nhra side. car is 3100lbs now in ihra trim.
Herb Jr
Old 11-05-2008, 08:06 PM   #6
buzzinhalfdozen
Ray, shift 9300-9400 no air shifter yet cross finish line 9700-9800 falls back to converter obviously on shift. Only have maybe 8 runs on car mainly trying to get an idea of what converter I'll need as well as trans ratio, first gear is 2.45 I believe haven't had chance to try other trans yet. To be honest this auto trans took me e few runs to get used to shifting it, stick seemed easier, I actually used to shift my 5- speed set up at 9700-9800 however had more drop between gears. Not sure if I need to run engine higher between shifts or not as I don't really have a lot of info yet on this set up. Thanks Joe Sorry Ray just looked at my data logger shift rpm is correct but finish line is 9350 seems to be still pulling strong, 6.50 gear 101 roll tire, believe I need to go with less roll tire. Joe
Old 11-06-2008, 06:42 PM   #7
buzzinhalfdozen
Ray off topic do you run an even or odd fire engine? I have the stuff to do an even fire but man looking at the even fire crank scares me. Joe
