Liked 20 Times in 15 Posts
I'm looking for some Pro gears for a Mopar rear. Seems that the Richmond gears are only street rated and other sources are imports. The set up s for a C/SA Dart. Any help? Thanks
Liked 574 Times in 212 Posts
Look at Motive and Strange and see if that is what you want.
Liked 307 Times in 116 Posts
The Richmond gears hold up quite well when set up properly.The pro gears are softer and usually used in 4 speed cars. A C/SA Dart with a 440 running 1 sec under should get a good 4 seasons on the street set.The pro set might be mush by then. The street gears can be softened a bit with good results, resulting in the best of both worlds. If the gears are not set up properly, as is typically the case with the 8 3/4, the extra money is wasted. Paul.
I bought my Motive Ring & Pinion from Mancini Racing in Roseville, Michigan. He also carries Strange and Richmond.
Nelson Kowal Stock 345 |
Liked 13 Times in 9 Posts
Go ahead and get the street gears, and then send them to Jim Bailey at FINISHED to have them REM-finished and Cryo'd.... stronger, more durable, more less friction. www.finishedracing.com
Does anyone sell pro gears still? I could not find them on Richmond's website anymore. I am looking for a set of 4.30 gears, for use in a Super-Gas car. When I ran street gears in it before, I was going through 2 sets per season. My original set of pro gears (came with the rolling chassis) worked for 2 seasons, and the set of custom-made pro gears (bought them from a stock/SS racer years ago) is still working after 2.5 seasons.
Regards,
Michael Pliska 643 S/G |
Liked 353 Times in 102 Posts
For gear needs go to Strange direct or Mark Williams.
Both are very helpful if you call. They both know their products and both pay the contingencies on time should you get to that point. Both have good people. My 2 Cents |
Strange has a 4.86 pro gear, I think that the only pro gear you can get for the 8 3/4.
Good Luck |
