Old 10-16-2008, 07:00 AM   #1
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
Default Coil spring/ control arm suspension
I have a 67 chevelle (coil spring/ control arm rear suspension). i have QA1 adjustable rear shocks in the car, i am wondering should i also be putting a rear sway bar in the car to help stop body roll at launch or just tighten the right rear shock?
Also i see that Hotchkis makes a 1 5/16 rear sway bar that has a "no-bind" connection point to the control arms. It hangs down from the control amrs about 2". is this a legal modification for a stocker?
Thanks
Ian
Ian Hill is offline   Reply With Quote
Old 10-16-2008, 09:26 AM   #2
Jim Kaekel
Liked 539 Times in 112 Posts
Default Re: Coil spring/ control arm suspension
Using an Air Lift air bag in the right rear coil to preload the suspension will help your problem, but the best fix currently available that I have seen and used on my '70 4-4-2 is the HR Parts 'n' Stuff rear sway bar. It is a tubular, chrome moly rear sway bar with adjustable heim ends. Easy install, drill four holes and bolt it on.
Jim Kaekel 3836 STK
Old 10-16-2008, 09:31 AM   #3
SSDiv6
Thanks
Ian
Check out the sway bars from the following vendors:
http://www.hrpartsandstuff.com/
also the Xtreme Sway Bar from BMR Fabrication...
http://www.bmrfabrication.com/A-Body.htm
and Spohn Performance...
http://www.spohn.net/shop/1968-1972-...72-A-Body.html
Old 10-16-2008, 10:15 AM   #4
Greg Barsamian
Liked 427 Times in 97 Posts
Got 2 Chevelles that run the BMR Fabrication Xtreme sway bar.
1 Big Block 66 SS w/ Nash 5-speed, and a 70 SS small-block car w/ Jerico 4-speed.
Both cars picked up 2-2.5 tenths using this system w/o Air bags! you don't need them!
Old 10-16-2008, 10:28 AM   #5
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
x2
My 66 Chevelle stocker with a 283/pg goes 1.51 60' with the HR Parts anti roll bar. Go with the cheapest shock you can find on the rear. The front spring and shock combo varies, just keep working it. It took me all year to get mine figured out, but it works good now!
Wade O
Old 10-16-2008, 09:09 PM   #6
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
The HR bar works really well. Check out the video to see how it works.
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 10-20-2008, 08:32 AM   #7
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Thumbs up Re: Coil spring/ control arm suspension
I also use the HR bar on my '70 Cutlass. I love what it did for my leave.....
Old 10-20-2008, 10:41 AM   #8
Dave Goob Cook
Dave Goob Cook's Avatar
Having solid or fresh bushings in the control arms, as well as mounting points that are not wallowed out goes a long way, before you spend on bolt ons.
The air bag never did much for me, but I launch on a t-brake.
Dave Goob Cook is offline   Reply With Quote
Old 10-20-2008, 10:43 PM   #9
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Ian. The chevelle looks great. Looks just like a stocker and hope to see you out next year with that crate motor. As far as the car goes id be ordering a set of moroso coils for the front and get that nose in the weeds. It probably could come down 6 inches or more. I didn't get to see it make a run but with your fab skills I would be building an anti roll bar for the rear that "bolts" to the frame rails. That way it falls under the catagory "bolt on traction device" and will pass tech. I made mine out of 1 5/8 roll bar with 1 x 3 for the arms. With 1 to 2 turns of preload on the passenger bar I have been 1.34 with the back wheels in 60 ft.
When I use to run my car on the motor I would crank the pass side air bag to 30+. It would sit all crooked and ignorant in the pits but when it left it would leave perfectly straight. When I was running 11.40's It would go 1.46-1.49 in 60ft. Ohh and I used Southside Machine (now Mr. Gasket) lift bars for lower control arms. They work great. I always ran stock uppers with bushing. I have adjustable ones now that are set to factory length.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 10-22-2008, 07:03 AM   #10
Ian Hill
Ian Hill's Avatar
i have the moroso front coils in the car, but they are the heavy set, i also have the 1550-1650lbs springs and the ones rated for less front weight. i will be swapping them in and out until the car works the way it should. i have also already ordered the hotchkins "extreme style" anti roll bar for the rear.
not making it over to see my run was nothing at all, as Raymonds motor was way off on the tune up, it studdered and poped off the line to a 11.55 @119, all four wheels on the track - that and the fact the converter choice (my falt) was wwwaaaaayyyyyy off did nothing for the launch. i think i shifted into second around the 400 ft mark. either that or KC sold me 2.73 gears instead of 4.88's!
what do you mean crate motor...hmmmmm. word travels quickly around here. i had the deposit in my pocket and as soon as he hit the 10's i went over and did the deal. h/cm here we come.
Ian
