Old 10-15-2008, 04:53 PM   #1
MYLINRACING
MYLINRACING's Avatar
Default 82-92 headers
Trying to see what headers work best with these cars in stk elm. I have hedman on there know i was looking into stahl or ed quay.
Andrew Mylin
MYLINRACING is offline   Reply With Quote
Old 10-16-2008, 11:13 AM   #2
Ron Miller
Liked 13 Times in 7 Posts
Default Re: 82-92 headers
Andrew Mylin
Look at the Stahl , Hookers, etc. Stay away from the Quay headers. I have them on my 92 Camaro SB car and they are a pain in the ***** to install and work around. Number 7 plug is impossible to install from the top, you have to jack up the car and install from the bottom. You will also have to grind on the block on the left rear top part where the clutch ball pivot is and where the dip stick is & a square locating casting on the block. At the time I was building this car, Quay was the only one that had headers to fit a SB. The BB headers fit real good and are easy to work around and getting to the plugs.
Ron 92 Camaro GT/DA
Ron Miller is offline   Reply With Quote
Old 10-16-2008, 03:25 PM   #3
bobby
bobby's Avatar
Every set of Hookers (not the ones on Broadway) I have seen fit great but didn't last very long. Always rusted, even the coated ones, and the collectors fell off at 1000'.
bobby is offline   Reply With Quote
Old 10-17-2008, 12:27 AM   #4
NovaMan
NovaMan's Avatar
Is this for a small block? A friend of mine has Hooker Super Comps on the small block in his 92, and spark plug access is AWESOME. Also, his haven't rusted or fallen apart... I'm pretty sure they're coated, but I don't know if Hooker did it or if he had them coated after he bought them.
~Pete
1970 Nova
NovaMan is offline   Reply With Quote
Old 10-20-2008, 09:11 PM   #5
Chuck Porter
I use Hookers on our Camaro. They fit fine and so far no rust.
If you want an excellent little spark plug tool for working around headers check out this link. I have these and they are well worth the $$. http://www.headersockets.com/
Chuck
Chuck Porter is offline   Reply With Quote
