Old 10-10-2008, 08:49 PM   #1
stock eliminator
Default new at this have question about engine blocks
I was wondering if you can bore out lifter holes and put in larger lifters and/ or put bushings in them. Question two can i put 4 bolt mains in a 2 bolt main block. Question three can i use a gridle on my mains to tie them all together. Question four can i use tubing to redirect the oil back to the oil pan. Question five can i use a windage tray. This is for a 1986 J/SA 305 Camaro NHRA rules thanks
stock eliminator is offline   Reply With Quote
