Old 09-29-2008, 11:58 AM   #1
cyclecyko
cyclecyko's Avatar
Default minimum weight
Between the website and the rule book the nhra could not have made minimum weight more confusing.
I'm looking for my 325hp/383 in a 66 coronet wagon. The website says 3936 lbs but the rule book makes it out to be like 4500 lbs. The car is completely stock weighed less than 4000 lbs.
Am I retarded here ?
cyclecyko is offline   Reply With Quote
Old 09-29-2008, 12:10 PM   #2
5919 SSKA
Liked 19 Times in 5 Posts
Default Re: minimum weight
NHRA Corrected Hp x Class wt + 170 (for driver).
Racing web page
5919 SSKA is offline   Reply With Quote
Old 09-29-2008, 12:21 PM   #3
Bill Harris
Liked 26 Times in 13 Posts
maybe not retarded, maybe just a victim of our fabulous educational system... 66 Coronet SW with a 383/325HP, NHRA rated at 280 HP for stock depends on the trim of the wagon.
Coronet Deluxe has a shipping weight of 3913 and a break of 13.98. It is a natural L (13.50 to 13.99). NHRA allows you to run at the bottom of your natural class so in L your minimum weight is (13.5*280)+170= 3950 lbs (the 170 is always added for the driver). NHRA also allows you to go up or down one class from the natural class. So you can also run K at a min of (13.0*280)+170=3810 and M at a min of (14.0+280)+170=4090.
Coronet 440 6 passenger has a shipping weight of 3936 and a break of 14.06 while the 9 passenger has a shipping weight of 3949 and a break of 14.10.
Both the 440 versions are natural M (14.00 to 14.49) and could also run L at 3950 lbs min, M at 4090 lbs min, or N at (14.5*280)+170 = 4230lbs min.
Hope that helps you out!
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 09-29-2008, 12:56 PM   #4
cyclecyko
cyclecyko's Avatar
Thanks Bill, I was not aware of the hordepower being corrected to 280. I guess I was also unclear on how to factor everything. Do you think this will be a competitive combo ? I haven't seen many 383 chryslers in stock.
Old 09-29-2008, 01:15 PM   #5
Bill Harris
I'm not the right guy to evaluate Chrysler combos, (or any others for that matter). It seems like 280 HP is fairly low for the engine specs, but that 280 was last changed in June 2003. It would be interesting to know whether the adjustment was up or down and why. Someone has been messing with that engine in super stock since it was just changed to 290 HP last June. Might have been a letter asking for an adjustment or someone might have run too fast with it.
The only experience I have with a 383 is trying to avoid getting a heads-up against Jerry Bennett's '62 Savoy with the 383/343 engine. That one has two AFBs and a bit more cam than your engine, but it also has a 320 HP NHRA rating, 40 HP more than yours.
There are lots of Chrysler guys on this site, maybe they will chime in.
Bill Harris
ex 2172 STK
ex 2272 S/S
Old 09-29-2008, 01:17 PM   #6
Jeff Lee
Jeff Lee's Avatar
The shop I use built a 280 (corrected) HP 383. It has been #1 qualifier on more than one occassion this year. I thought the 426W-4bbl was available as an option but apparently it is not. That would be an engine up to 1965 and is factored to 300 HP.
Jeff Lee 7494 D/S '70 AMX
Old 09-29-2008, 01:20 PM   #7
cyclecyko
cyclecyko's Avatar
I've flowed a stock chrysler heads on a superflow. 2.3 hp per cfm is generaly thought of as the maximum hp for a givin head. That means my combo would be maxed out at about 480 hp. The car is probably only going to run about 0.70 under the index. Again mabey I'm wrong my flow numbers are from a head with a factory valve job. A set of heads done right migh make 500hp. Any input is appreciated.
Old 09-29-2008, 01:37 PM   #8
Ryck Campbell
Ryck Campbell's Avatar
Liked 46 Times in 10 Posts
The 3936 that you are referencing is the shipping weight of a 1966 Coronet 440 station wagon 6 passenger. For stock eliminator, the 383 325 hp is rerated to 280 hp. That makes it a natural "M" with a p/w factor of 14.06. Since you can move up 1 class and down 1 class, it would have to weigh 3950 in "L", 4090 in "M" or 4230 in "N", all including the driver.
hope this helps,
Ryck Campbell
NHRA D-1 Tech Director
Ryck Campbell
NHRA Technical Specialist
Ryck Campbell is offline   Reply With Quote
Old 09-29-2008, 05:16 PM   #9
cyclecyko
cyclecyko's Avatar
I assume that the 318 combo for this car would have to run a polly 318. does any one know this to be true or are they allowing LA motors ?
Old 09-30-2008, 12:53 PM   #10
John Lang
Liked 6 Times in 2 Posts
Thumbs up Re: minimum weight
Cyclecyko, Stick with the 383/w 4bbl. Check out Jim Hale's 67 cuda with a 383 4bbl!!!!! He's able to run a second under at will. That would work well in your wagon I feel! Using the 915 heads, with the smaller ex valve,1.60 could be a competitive combo. Make sure you have a well setup rear ..Good Luck, John Lang. A Mopar lover.
John Lang 365 STK, SS
John Lang is offline   Reply With Quote
