Old 09-21-2008, 10:01 PM   #1
Philip Saran
Liked 14 Times in 11 Posts
Default Line lock lines??
I'm at the point of remounting the new M/C and hooking up the
line lock.
Problelm: 1974 Duster/383 BB/1-7/8 hooker super comp fenderwell
headers which run just under the M/C. (I have a new heat shield for
under the M/C).
I am switching over to the more modern version of the 2 bolt M/C with
the 4 bolt adapter and I want to mount the line lock unit to the left of
the M/C on the firewall, but do I use hard lines or flex lines??
With the fenderwell headers I need to remove the M/C if I need to remove
the left side header.
Open to comments and opinions.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 09-22-2008, 02:32 PM   #2
David Lee
Liked 346 Times in 126 Posts
Default Re: Line lock lines??
THats ones easy, nothing but hard lines
Old 09-22-2008, 03:16 PM   #3
Harry 6674
My son has a 67 Barracuda-440-fenderwells with flexible stainless brake hoses with no problems. Started with auto parts brake hoses and they didn't work as well as the stainless ones. Less expansion with the stainless.
Harry 6674 is offline   Reply With Quote
Old 09-22-2008, 04:55 PM   #4
Philip Saran
But are the S/S flexable lines legal for NHRA?
Thanks for the responses.
Phil Saran
Parker, Colorado
Old 09-22-2008, 05:56 PM   #5
Harry 6674
He doesn't have any problems with tech and I've got them on all four corners but I don't have rule book with me at work so I can't tell you for sure.
