Old 09-13-2008, 10:09 PM   #1
Randy Schonscheck
Liked 2 Times in 2 Posts
Question ZZ4 And Fast Burn Headers
I have read that the ZZ4 and Fast Burn Cylinder heads have the exhaust port roof .100 taller than standard heads. Has anyone run into a problem finding headers that fit this port layout with 5/8 or 3/4 tubes. If not, what do you do???
Thanks!
Randy
Randy Schonscheck is offline   Reply With Quote
Old 09-13-2008, 11:03 PM   #2
SSDiv6
Default Re: ZZ4 And Fast Burn Headers
Thanks!
Randy
No problems when using Hedman Headers. They make Headers to fit the taller exhaust ports in 5/8. 3/4 and 7/8.
Old 09-14-2008, 07:39 AM   #3
Mike Savelle
Liked 7 Times in 5 Posts
Wink Re: ZZ4 And Fast Burn Headers
No problem with the ZZ4 , its the fastburn . We elongated the header bolt holes and it worked ok on our car . We had Hooker 1 3/4 headers . Hope this helps . Mike
Mike Savelle is offline   Reply With Quote
Old 09-14-2008, 10:25 PM   #4
Randy Schonscheck
Thumbs up Re: ZZ4 And Fast Burn Headers
Thank You SSDiv6 and Mike. I couldn't get an answer around here, most didn't know there was a difference. Thanks Again! Randy
