Old 09-08-2008, 05:21 PM   #1
RJ
Default Driveshaft
I am needing about a 3.5" diameter 57.5" long driveshaft that needs to go about 6500 rpm. The driveshaft people I've talked to say that a shaft that long' going that fast will be over the critical speed. I see lots of station wagons racing out there that don't seem to have any problems, what is everybody using at about this length?
Thanks
RJ is offline   Reply With Quote
Old 09-08-2008, 11:35 PM   #2
69Cobra
Liked 2 Times in 2 Posts
Default Re: Driveshaft
http://www.dynotechengineering.com/
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 09-09-2008, 12:05 AM   #3
Pat Cook
RJ, I had the same problem with my "slug" until I put a Dynotech drive shaft in it, cured the problem.
When I had the rubber filled drive shaft it did not shake, after the "Canadian Transmission" was installed, it took 3 drive shafts until I talked to the guys at Dynotech and bought one of there shafts.
67 Ford Fairlane
F/SA
749
Pat Cook is offline   Reply With Quote
Old 09-09-2008, 12:29 PM   #4
Run to Rund
Liked 54 Times in 27 Posts
4" diameter would be recommended for that length and speed. You can find a critical speed chart at www.markwilliams.com
