Old 08-26-2008, 08:50 AM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default 12 bolt crush sleeve vs. solid spacer w/shims
I am starting to gather the parts to get my 12 bolt assembled and am wondering if I should toss the stock style crush sleeve in favor of a solid spacer with shims to set the pinion bearing preload. I already have the crush sleeve as part of the bearing kit but if it will make the rear gear set last longer or benefit bearing wear I will order up the solid spacer.
Please share your thoughts / experiences.
Chad
Chad E532 is offline   Reply With Quote
