Old 08-24-2008, 12:15 AM   #1
7423
Default 95 Mustang front brake and Weld wheel issue
Using Weld Draglites on my stocker in progress. Installed a set of 3" studs in the hubs, attempted to mount the wheel and found that it take 1/2" spacer to clear the wheel from the very fat OEM caliper. This will not work as now I do not have enough thread engagement in the lug nut. I guess I will be looking at new aftermarket billet thin body calipers. On many of the Mustangs websites, there is talk of grinding the caliper body and using spacers, not my cup of tea. Anyone out there have or had this problem??
Thanks in advance............
Charlie Allen
7423 is offline   Reply With Quote
Old 08-24-2008, 09:52 AM   #2
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
Default Re: 95 Mustang front brake and Weld wheel issue
I run a 91 Mustang, and alot of the guys around here were using the 94-94 spindles and brakes on the fox cars had similar issues. I used a SVO 5 lug setup on mine, with the stock 91 GT caliper, had no issues clearing the caliper at all. I have also read of people hacing to space out the fronts using Aerospace and Wilwood front brakes, may want to look into that a little more before you spend the $$$ for the same issue.
NHRA: Comp 2200 - S/C 2201
NMRA 2012 Outlaw 10.5 #10
Freddie is offline   Reply With Quote
Old 08-24-2008, 09:59 AM   #3
SSDiv6
Charlie Allen
The aftermarket brakes sold by Strange,Aerospace Brakes and Lamb for the SN95, use OEM spindle and only replace the caliper and rotor. My preference is Strange.
Also, you can buy a replacement race caliper from The Brake Man:
http://thebrakeman.com/home
You can also try to get the PBR calipers and brackets from a 1999 or later Mustang in the wrecking yard. The PBR caliper is a 4 piston caliper and the body that faces the wheel is smaller.
