Old 08-02-2008, 01:00 PM   #1
Joe DeMarzo
Liked 113 Times in 9 Posts
Default Dish piston vs Notched
Which piston is better in a stock eliminator car and why? Does the notch piston/head make up for the compression that a dish psiton/head may have? Or does the dish piston create a hotter burn with a better head compression ratio? No specific combo in mind and everythinhg else being equal.
Thoughts?
Joe DeMarzo 1317 STK
Old 08-02-2008, 10:10 PM   #2
Bub Whitaker
Default Re: Dish piston vs Notched
Ok Joe.. typically a flat top piston with valve reliefs and a quench type head/ SBC will make a better burn - more efficent power than the same head with a dish piston. Explain? I don't have a deploma from anywhere you just have to trust me... but if your refering to Stock Elim, then you don't have to worry cause I'm pretty confident that the HNRA \ I mean the NHRA has a handle on all the engine/ HP figures so as to level the playing field. He He
Bub Whitaker is offline   Reply With Quote
Old 08-03-2008, 08:34 AM   #3
Joe DeMarzo
Bub, thank you for the insights, your word is good for me. I see some fast cars out there and try to figure out some of the performance related to combinations. One more question, if the cam is the same is the head with more compression better (even though it is a dish piston)? This one intrigues me, again thanks.. See ya soon, maybe at the Keystones we can finish this conversation.
Old 08-03-2008, 08:48 AM   #4
Liked 1,777 Times in 404 Posts
Joe, are you comparing a piston with a full round dish to a flat top with valve reliefs? Or are you comparing a piston with a full round dish to a piston with a reverse dome?
Provided the actual compression ratio is the same, there's nothing more efficient than a flat top and a decent chamber design (meaning the head has a chamber and both a squish side and a quench side).
A full dish is much less efficient, even with a good tight chamber, because the full dish prevents the squish and quench parts of the chamber from working.
A reverse dome is only somewhat less efficient, because the reverse dome design takes almost full advantage of the squish and quench parts of the chamber.
IF the head is the EXACT same head, and the cam is the same, and the ONLY difference in the compression is the design of the top of the piston, then the dish piston engine will make less power. Provided all else is equal as well.
Old 08-03-2008, 04:25 PM   #5
rustbucket79
The combination that has the most compression wins. You are restricted to the legal piston and head so changine either one to an illegal part is a big no no in class racing.
rustbucket79 is offline   Reply With Quote
Old 08-03-2008, 06:24 PM   #6
Mark Lewis
Liked 207 Times in 44 Posts
Most of the dish pistons you are talking about have a flat surface about .300 wide around the outside diameter of the piston and with about 10cc less combustion in the head that helps get the compression up more than the flat top with a bigger head.The camshafts are equal in factory specs. But you still have to maximize the whole combination.
Mark
Mark Lewis is offline   Reply With Quote
Old 08-04-2008, 05:39 PM   #7
Joe DeMarzo
Thanks for the insights, I appreciate the honesty. It will be helpful someday. Hope everyone has a win in their future....
