Old 07-29-2008, 06:54 PM   #1
RJ Sledge
Liked 292 Times in 92 Posts
Default Total Seal gas ported ring spacer?
Was ordering a set of rings from Total Seal and they asked me I if I wanted my spacers gas ported. I had heard someone talk about the setup, but wanted to know if anybody had tried them before? TS gets about $240.00 for a set and for that price I would like some opinions. Thanks RJ
RJ Sledge is offline   Reply With Quote
Old 07-30-2008, 01:01 AM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Total Seal gas ported ring spacer?
I don't know about Gas ported spacers but I've gas ported rings. Sounds like a good way to keep from reworking replacement rings every time you do a freshen up.
Adger Smith (Former SS)
Old 07-30-2008, 01:36 AM   #3
Jeff Lee
Jeff Lee's Avatar
I've known a few that have gone this route. Seems to work.
This is another one of those ideas that while legal, just make the racer spend more.
Jeff Lee 7494 D/S '70 AMX
Old 07-30-2008, 11:10 AM   #4
RJ Sledge
I just talked to Adrian Pendergrass @ Precision Measurement Supply (210-681-2405) and he makes a fixture for doing them yourself. $140.00 and includes the Carbide End Mill. That way you only need the spacers ($30.00) and you can make all you want. Mill access would be needed. Give him a call and check out his web page Precision Measurement Supply.
Old 07-30-2008, 07:50 PM   #5
Woodro Josey
Liked 3 Times in 1 Post
RJ, i have been using them for a while and i had to machine my own spacers, now they are machining them and yes they do work!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 07-30-2008, 09:53 PM   #6
RJ Sledge
Appreciate all the info everybody, I am going to try them. Thanks RJ
Old 07-30-2008, 10:05 PM   #7
Jim Cimarolli
Liked 166 Times in 46 Posts
Smile Re: Total Seal gas ported ring spacer?
R.J.
Back in 1961 there were some Mercury pickups built in Canada that had an FE engine with gas ported pistons. They were also equipped with a C-4 transmission. I would petition the NHRA for the rightfull parts that should be superceded for your car based on that truck from 1961 so that you can just run a gas ported piston instead of all those high tech expensive ring spacers.
Jim C.
Jim Cimarolli is offline   Reply With Quote
Old 07-30-2008, 10:12 PM   #8
Chad Rhodes
Originally Posted by Jim Cimarolli View Post
R.J.
Jim C.
you crack me up Jim
Chad Rhodes 2113 I/SA
