Old 03-28-2007, 01:07 PM   #1
Caperat
Default DANA -- 70 -- Information
I have a one ton DANA 70 rearend with a 4.56 gearset. I want to install a 3.70 gearset in it's place. Would anyone out there know what is required to do this change along with the parts that are needed. This DANA has the 9 or 10 bolt cover which i was told was the old style. Lets hear from the experts. --- Thankyou
Kevin MacLeod
Caperat is offline   Reply With Quote
Old 03-28-2007, 04:01 PM   #2
SSDiv6
Liked 1,535 Times in 572 Posts
Default
Go to the website of randy's Ring and Pinion. They have everything you need to change gears.
http://www.ringpinion.com
Old 03-28-2007, 07:57 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 844 Times in 233 Posts
Default
You will be going past the split point for the carrier. ... You will need a different differential if you go numerically lower than 4.56 ... Tom
Tom Goldman is online now   Reply With Quote
