Old 03-27-2007, 10:54 PM   #1
deep
Default 305 vortec heads
I have used 350 vortec heads in the past with great results, but found some 305 vortec heads and was wondering if they will perform as well as the 350's?also I noticed the 305 heads have a 58cc chamber,and was wondering if I would still be able to run pump gas with a 350 flat top piston?thanks!
deep is offline   Reply With Quote
Old 03-28-2007, 01:46 AM   #2
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Default
if you use a thick head gasket maybe. 58cc on a 350 will make it like better then 11to1. as to the "vortec" 305 heads....? do you mean center bolt valve cover heads? or the late 90's vortec truck heads?
novamoation
Old 03-28-2007, 11:09 PM   #3
deep
Default
yeah, its center bolt valve covers, and they supposedly come off a late 90's model pick up.
Old 03-29-2007, 03:41 AM   #4
greg fulk
greg fulk's Avatar
Default
deep it's one of those deals that "IF" you can get them cheap try them! a head gasket set from "the-zone" is about .050 so it may work fine.
novamoation
Old 04-16-2008, 01:26 PM   #5
crazyponcho
Default Re: 305 vortec heads
a word of caution, if you are using flat tops and just using a thick gasket to drop compression you may just make the engine even more detonation sensitive since you are loosing all of your quench. You would be better of using a dished piston or grinding the combustion chambers bigger and running a quench of .038 to .040. It will be less detonation sensitive and probably make an extra pony or two over having a a quench of say .050
crazyponcho is offline   Reply With Quote
Old 04-17-2008, 06:25 AM   #6
Adger Smith
Liked 880 Times in 311 Posts
I have a 305 head combo I've been using on some circle track limited engines. Better check the out side water passages (spark plug side) & the fire ring of the gasket. A lot of these heads are cast where the fire ring of the 350 bore gasket hangs over, or almost into, the water passage & leaks. Otherwise they will work. I do hope you mean the head WITHOUT the swirl ramp under the intake valve. That is a true Vortec. You are wasting your time using the heads with the swirl ramps. They quit flowing @ around .425 lift. They are great for what they are designed, low end power in trucks & cars. Max swirl. You will never be able to run them on a 350 with pump gas. About 11-1. I always do an unshroud on the valve pockets to pick up the flow & they end up around 66-68 cc. The flow is worth more than the compression.
Adger Smith (Former SS)
