Old 05-24-2008, 12:12 PM   #1
mrolds
mrolds's Avatar
Question Best tires for heavy ,torky high 10 sec car?
I really don't know which forum to go to, but you guys seem to yank the wheels better & have to follow more tire rules, so I figured I would try here.
I'm having trouble hooking consistently with my ET streets ("12.5" X 30) & wanted to get some input before I throw money at some new slicks.
The car is an all steel 67 Cutlass, 461 Olds, t400, 4800 stall, 3.70 9" rear, H&R sway bar, air bags at 6 lbs, full 3" Pypes exhaust w/ X pipe. Guessing at least 3700 lb w/ fat driver.
Best ET to date is 10.909 @ 124. Mainly a bracket car but want to be able to dabble in the 10.90 classes.
I was thinking about stiff sidewall slicks. I'm limited to 10.5" wide & 30" tall. If I go a little narrower & or shorter I could lose the air bags.
Any suggestions would be appreciated!
Jeff Smith S/ST- Pro/ET 5102
Creating the streetable S/ST Olds
mrolds is offline   Reply With Quote
Old 05-24-2008, 12:57 PM   #2
Floyd Staggs
Floyd Staggs's Avatar
Liked 223 Times in 98 Posts
Default Re: Best tires for heavy ,torky high 10 sec car?
Jeff, I have a 4000 lb pickup, high 10's, with MT ET streets 13.50x30x15. I put on a set of ET Street Radials and picked up .05 in 60' and a tenth in the eighth. The only problem I have is tire shake or wheel hop on a hot track. I have a ladder bar suspension but I think my springs are too stiff and my shocks set too loose.
Floyd Staggs 787 SST
Old 05-24-2008, 01:17 PM   #3
40Coupe
Look no further than a set of Hoosier 30 x 10.5 C07 radial slicks in either 92.5 or 94" rollout. You'll like them!
'67 Camaro
1.25
5.77 @ 118
40Coupe is offline   Reply With Quote
Old 05-24-2008, 11:38 PM   #4
mrolds
mrolds's Avatar
Thanks guys!
Floyd, just out of curiosity, what size et street radials did you go with?
Old 05-25-2008, 10:01 AM   #5
Floyd Staggs
Originally Posted by mrolds View Post
Thanks guys!
315x60Rx15. I wanted to stay at 30" diameter for my gearing.
That's also the biggest I can get under my fenders without cutting it up.
Old 05-25-2008, 08:44 PM   #6
Ed Wright
Ed Wright's Avatar
Yep, and mount them on 12" wide wheels.
Ed Wright 4156 SS/JA
Old 06-01-2008, 12:13 PM   #7
mrolds
mrolds's Avatar
Well, I went with the Hoosier radial slicks in 92.5" rollout.
MUCH BETTER!
With just a light burnout they hooked hard!
60's got a bit better every pass.
They held the same pressure all night! (20#) They did slip on the rim about 3".
Made it down to 6 & was up for the bye & fell asleep with a .11r/t & broke out by .002.
Thanks guys!
Old 06-01-2008, 12:45 PM   #8
40Coupe
Jeff,
Glad we could help and glad to hear you're hooking and better yet going quicker!!!
'67 Camaro
1.25
5.77 @ 118
