Old 04-18-2007, 09:32 PM   #1
Sean Ward
Sean Ward's Avatar
Send a message via AIM to Sean Ward
Default any gains chageing fuel brands
used vp for first time this past weekend and gained a ton is this possable
oh when i say ton i mean a half sec . can this happen it was not just one run i was all my runs all weekend were fast
sean ward
stk# 2882
Sean Ward NHRA s/ss/comp#2882
SW4 MOTORSPORTS
Sean Ward is offline   Reply With Quote
Old 04-18-2007, 11:58 PM   #2
Jeff Lee
Guest
Posts: n/a
Default
Not normal. My first thought is you had some really bad (old) gas in the tank or completely wrong octane rating? What did you have and what VP did you change too?
If it's that good, I'll take a few gallons!
NHRA #7494 SS/H
1970 AMC AMX 390
"Best Appearing" @ NHRA '06 Pacific Sports Nationals
Arizona's BEST Realtor since '93 and I support racers!
Property in AZ or moving here? I can help! Call me @ 602-418-9797 or e-mail JeffLeeAzRealty@Qwest.net
Old 04-19-2007, 09:14 AM   #3
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Default
Sean to pick up that much you have Ignition issues to work. You have energy to light the one fuel but not the other.
Ensure ignition has 14 Volts
OHM check wires
Research current coil Amp output - The new HVC coils are strong
Platinum plugs seem to work very well in Low Comp. engines
Run a stand alone heavy gauge wire direct to battery to toggle switch for ignition. Bypass factory key switch ( too much voltage drop )
At least 100 Amp Alt -- some cars pick up 2 tenths.
Daran - Tina
2057 SS/MA
2050 K/SA
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 04-19-2007, 03:06 PM   #4
Sean Ward
Sean Ward's Avatar
Default
Jeff i have always run sunoco purple 110 but could not get any so i drained tank and got vp c12 from vp trailer a track thats the first time i have ever put vp in my car my dads car runs vp course his car has issuses right now
Darren yeah don't know how but changed fuel and car ran fast bet i don't change back
sean ward
stk# 2882
SW4 MOTORSPORTS
