Old 04-07-2007, 01:21 PM   #1
BOBBY THOMPSON
Default alternator worth e.t. ?
any feed back on a working alternator and hot battery in a stocker being worth some e.t. after talking to several racers at memphis i have replaced both on my camero hoping to pick up a little before dallas points race. engine in the car is very out datedso trying to pick up all i can with bolt on's and go into engine this winter..thanks for any help b.t.
racer bob
BOBBY THOMPSON is offline   Reply With Quote
Old 04-11-2007, 09:47 PM   #2
Ed Wright
Ed Wright's Avatar
Default
Boby, I see nobody answered this. I don't claim to know as much as others here, but did expriment with this on my bracket car (soon to be super stock I hope). Mine is a '96 Firebird with an LT1. Factory EFI and still has the original 4L60E, so voltage is probably more important than a carb car. With the alternator shut off, mine lost 6 or 7 rwhp on my chassis dyno, very consistantly. So, I figured a 16 volt battery & no alternator would run close to the same voltage going down the track as a 12 volt with the alternator charging. It does, but makes the same power, and runs the same times at the track as the 12 volt & alternator.
My power windows are faster with the engine shut off. <G>
Good luck, Ed
Ed Wright 4156 SS/JA
Old 04-20-2007, 11:21 PM   #3
BOBBY THOMPSON
Default
thanks for the input Ed ,had valve spring problems last weekend at ennis so not sure how much it helped if any.but going to rusk tx in 3 weeks to try it again...........
racer bob
