Old 04-17-2007, 04:28 PM   #1
68Mustang
Liked 2 Times in 2 Posts
Default Couple of questions about new 68 Camaro combo
Just bought a 68 camaro off a friend. it is his old bracket car, he bought a dragster.
I am going to build a 350 for this car, and even though it is a bracket car i would like some of your suggestions, i am amazed at what class racers can do with the rules you have to run under., and how hard the cars leave
I am going to run
10:1 compression
RPM intake
Edelbrock RPM heads
1 5/8 headers
going run either a 750HP or 950HP
will be running 28x10 slicks
will be getting a 8" convertor
I am looking to shift around 6200/6300 1/8th mile only
my questions are:
what gear should i run
what duration and lsa cam should i run thinking either hydraulic or solid flat tappet no rollers
what convertor and how much stall
was kinda trying to approach this car like a I/J car. I see I/J novas running 7.20/7.30 in the 1/8th with rather impressive wheelstands on the internet all the time. would like this car to leave/run like that
Any suggestions or ideas appreciated.
68Mustang is offline   Reply With Quote
Old 04-18-2007, 02:37 AM   #2
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Default
My 2 cents....you need 1& 1/2 stepped to 1&5/8 headers..call ATI for a converter (your running a powerglide right?) you'll need at leats 250 deration @ .050 (if it were me run solid lifter their cheaper! ) find one that has .450 lift this will work good and give ya piston clearance...and I would put a 4.88 gear in it with a 28" tire. P.S. if your runnig a glide you'll need at least a 1.94 low gear...2.08 would be better. Good Luck!!
novamoation
Old 04-18-2007, 11:40 AM   #3
Dave Goob Cook
Dave Goob Cook's Avatar
Default
Run the 750 carb, 1 5/8" headers are fine, work with the collector length.
I'd look for a camshaft that is .550" + on the lift, duration @ .050" in the high 23x range on the intake side, high 24x range on the exhaust side, with a LSA of 110-112 degrees, to help with the low compression.
3-speed automatic?
Give it 5000-5200 + stall, you might be steep on the rear gear at 4.88's, but worth a try for 1/8th mile only, but I think consistency will suffer.
If you're going to try a pukeglitch, go up on the stall some more, like 5500+.
"Despite the high cost of living, it remains popular"
Dave Cook
C375
"Despite the high cost of living, it remains popular."
Dave Cook
NHRA N375
Dave Goob Cook is offline   Reply With Quote
Old 04-19-2007, 11:47 AM   #4
68Mustang
Default
How about the comp 282S it is 236/236 @50 495/495 110ls.
They say it is easy on springs.
If i would run this cam it has 4 degrees already ground into it should i advance it 4 more degrees to get it to leave harder.
With this cam i was thinking of shifting @6200 and getting a 8"ATI set up @5000.
What do you think it would run in a 3200 lb w/river and a 4.88 with 28x10.5 slicks
Old 04-19-2007, 12:18 PM   #5
greg fulk
greg fulk's Avatar
Default
fast enough to need a roll bar! lol Dad's car (67 camaro) with less gear & less cam will run 7.70's . it weights 3380 with him in it.
novamoation
Old 04-19-2007, 12:43 PM   #6
68Mustang
Default
what is your dad's combo.
is the 282S a good cam or would one with a split pattern work better, or one with a tighter lobe seperation.
i see Goob says to stay around 110/112 but that goes against what i have heard. not saying you are wrong, i don't know just wondering if someone could explained it to me.
Old 04-19-2007, 12:56 PM   #7
Dave Goob Cook
Default
I like split patterns on most all 23 degree SBC stuff.
The exhaust side usually needs help.
LSA is an overcomplicated term for overlap, the wide (bigger number) LSA is less valve overlap, helping keep the dynamic compression up.
I run a 106 LSA in my 15 to 1 stuff, narrower, higher power band.
If I were 10 to 1, I'd run 110 to 114 on the LSA.......
That isn't a bad looking cam you listed, but I'd at least run 1.6 rockers with it, your heads will support up to near .600" lift.
None of that has anything to do with the Intake Center Line method of degreeing the camshaft in.
I use the valve event timing specs on the card to determine if I'm installed straight up or advanced or retarded. The ICL method is quick and dirty, and depends on the cam being ground correctly, when I use the valve event timing method, I verify that the cam is ground correctly, or if not, I can split any minor differences in the valve event timing.
With that little cam you have listed, I'd run it retarded or straight up for a footbrake car. When you run past 5000 or so with the stall speed, there is no sense in enhancing the low end by advancing the cam.
You should be able to tweak that combo into the high 7's easily enough, and I don't think we need the roll bar down to 7.35 now days.
Dave Cook
C375
Dave Cook
NHRA N375
Old 04-19-2007, 01:22 PM   #8
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Default
I've got a 406 in my '68 with the RPM intake, 750 mech. sec. Holley, unported iron heads - I used the Comp XE284 hydraulic....240/246 @ .050, .507/.510 lift. It revs cleanly to 7000 and with a stock convertor in the 700R4 and 4.11 gears it runs 8.20s in the eighth (on Nitto street tires). I really like that cam - no shortage of grunt from 2000 on up. For what it's worth.
Paul Merolla is offline   Reply With Quote
Old 04-20-2007, 01:14 AM   #9
Brian Holcombe
Default
[IMaGe]http://i27.photobucket.com/albums/c181/SpeedyGoomba/blaunch.jpg[/IMaGe]
I fit all of those requirements and have gone 7.01 in the 1/8 11.15 in the 1/4
4.56 gear
converter flashes to 5000 (ATI 8")
108 LSA solid flat tappet cam, 242/248 duration at .050" and under .500" lift
Brian Holcombe is offline   Reply With Quote
Old 04-20-2007, 02:10 AM   #10
greg fulk
greg fulk's Avatar
Default
Dad's combo is OLD!!! it's a 280 magnum in strait up 462 "iron" heads 2.02 1.60 with 1.6 rockers Victor jr a plain old 750 duble pumper with a 9" 4500 converter with 4.11 gears & 28 X 9 slicks. 1.68 60' 7.78 @ 87mph
novamoation
