Old 05-07-2008, 09:06 PM   #1
7423
Default Any 5.0 Stock racers use an AODE trans??
Anyone try a lock up converter with an AODE? Pro and cons? A 4R70W gear set (2.84 low) will bolt in. Any opinions on the Compushift program? I am building a 1994 GT for O and P and would like to use a computor trans. Thanks in advance...........
7423 is offline   Reply With Quote
Old 05-08-2008, 04:54 PM   #2
Larry Munk
Default Re: Any 5.0 Stock racers use an AODE trans??
You have a PM
Larry Munk is offline   Reply With Quote
Old 05-09-2008, 12:01 AM   #3
7423
Thanks Larry
Check your PM;s
Old 05-12-2008, 08:43 AM   #4
Chris1529
Liked 70 Times in 29 Posts
I believe that after several test sessions and several thousand dollars, you will probably end up with a C-4 in the car. I don' think the advantage that you could get by using electronic shift and converter lock-up will be worth the money it will take to race that transmission. I am not saying it can't be done, or that no one out there can build the trans to hold up, but it will be a very expensive proposition to run.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
